inventor 2022 difference between simplify and create simplified part
donaldleigh
donaldleigh
Hi all
Can anyone explain the difference between "simplify" and "create simplified part"
to me they both seem to do the same thing, Converts an assembly to a part file.
Donald
Inventor 2022
sundars
Hi @donaldleigh
Correct! They are both identical in functionality. They both use the same underlying technology to take all the components of an assembly and derive them into a single part.
Create simplified part is a basic command which just gives you the option to control the output body type while Simplify part gives you greater control of the output body. Think of it as "create simplified part with options".
If you just want to push your components out to some part file and you dont really need to control features, then "create simplified part" is an easy command. But if you want to control what gets simplified, "simplify" is a better option.
Here are links to the help
Create Simplified Part
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-B0D9FF6F-938E-4A3A-8F1B-95B9B2D58BEA
Simplify
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-BE8EA563-BED0-432E-9B76-46FCD8E92006
Hope that helps.
-shiva
Shiva Sundaram
Inventor Development
donaldleigh
Thanks @sundars
