Incorrect Bend Direction in Flat Pattern
DustinMendoza
388 Visites
2 Réponses
Message 1 sur 3
DustinMendoza
I have this part that one of my guys sent out into out shop, part was CNC cut, and blueprints were handed to our press break operator. Upon assembly we noticed this part, it seems to backwards. The Actual Part matches the flat pattern with bend notes but it seems the flat pattern is reversed from even what the model shows in the sheet metal part. I can upload all the files, but i was hoping someone could explain a potential reason for this so i can prevent it in the future, to my knowledge ive never had it make an incorrect flat pattern as far as bend orientation and direction are concerned
probelm file is: "pie cut  - 4 - Hook"
0 J'aime
389 Visites
2 Réponses
Message 2 sur 3
Gabriel_Watson
Perhaps the A-side has been flipped/opposite than what needs to be up:
https://forums.autodesk.com/t5/inventor-forum/flat-pattern-always-flipped/td-p/9019666
0 J'aime
Message 3 sur 3
johnsonshiue
Hi Dustin,
It does look like a bug to me. It seems that either the bend direction is flipped or somehow the tagging was carried over from the source part orientation.
Interestingly, if I delete the flat pattern and add an A-Side definition, the Bend Note will be correct.
Many thanks!
Software Test Engineer
0 J'aime
