Inventor Forum
Import Rhino 3D Model
6 REPLIES 6
oliverC7F2D
289 Views, 6 Replies
Dear Forum,
I have a large 3D model in Rhinoceros 3D that I need to import/upload into Inventor. I can export from Rhino as .step or do I import as native rhino .3dm?
Oliver
6 REPLIES 6
johnsonshiue
in reply to: oliverC7F2D
Hi Oliver,
Either way should work. You can also export it to SAT 7.0. Inventor can import SAT files too.
Many thanks!
Software Test Engineer
oliverC7F2D
in reply to: johnsonshiue
Thank you very much, for your reply.
The Rhino model has all the different components as layers and sub-layers. Once imported is there a way to add the layers as components in the properties tree, as if it were modeled in Inventor?
Thanks Oliver
James_Willo
Importing to Inventor will just give you geometry, I don't believe you will get layers or other Rhino specific information. Please also check that you are on at least dot 3 release of whatever version you are using as that's when the latest translators are added.
James W
Inventor UX Designer
oliverC7F2D
in reply to: James_Willo
Thank you for your reply.
Is it possible to select the individual imported Rhino geometry in Inventor, and define it as solids, components or bodies?
Thanks ,
Oliver
James_Willo
I don't have a Rhino file to test, but I believe you get whatever is in Rhino. So if it's a surface in rhino, you'll get that in Inventor, if it's solid, you'll get solid.
James W
oliverC7F2D
Thank you very much for your help. I will get started and see what's imported.
Many thanks,
Oliver
