Inventor Forum
iLogic Configuration Missing
12 REPLIES 12
Message 1 of 13
BDCollett
826 Views, 12 Replies
Inventor 2023.1.1
I have an error showing up that the location of an external rule cannot be found (I imported my Application Options from another PC)
When I go to change it, the options are not there.
Any ideas?
12 REPLIES 12
Message 2 of 13
pcrawley
in reply to: BDCollett
Morning Ben - that makes things awkward 😂
It'll probably return if you reset the UI, but that removes all your hard work...  Try adding it back into the "Zero Document" environment using "Customise UI":
Peter
Message 3 of 13
BDCollett
in reply to: pcrawley
Thanks Peter, I did try those things.. the option is not even showing up in the Ribbon options though..
Very odd.. I don't know where it went!
Message 4 of 13
pcrawley
Oh, not good!  And Reset Ribbon doesn't bring it back?
Attached is a copy of a "clean" 2023 ribbon to try.  If I try it, I can see the "iLogic Configuration" option.
EDIT - Looks like you can't attach zipped .xml files to posts.  I've renamed it to .txt
Peter
Message 5 of 13
BDCollett
Still nothing. Might have to try a reinstall, something has gone a miss.
Message 6 of 13
pcrawley
Ah ha... Tools > Add-Ins - Enable the iLogic add-in and restart Inventor.
That should save you a reinstall.
Peter
Message 7 of 13
BDCollett
That was something else that I checked, it was enabled already.
This is the error when launching Inventor.
Message 8 of 13
A.Acheson
On 2022 Ilogic has there own import/export xml seperate to the applications object. You will have to have a file open and navigate to ilogic tab and export. This will export all the path settings to ilogic preference folder. This avoids having to remap manually the external rule locations.
Regards
Alan
Message 9 of 13
BDCollett
in reply to: A.Acheson
I exported the options from Inventor 2023  and imported them into 2023. Nothing from 2022.
Message 10 of 13
johnsonshiue
Hi! This could be an install issue. I would uninstall Inventor completely and reinstall it. Make sure all critical Windows updates are installed and .Net 4.8 is enabled.
Many thanks!
Software Test Engineer
Message 11 of 13
BDCollett
in reply to: johnsonshiue
Many thanks!
Hi Johnson,
It was working fine until I imported new Application Options. Strange issue.
I will reinstall.
Message 12 of 13
gdeber
same problem on Inventor 2024. Suddenly the iLogic Configuration desapears, and re-install doesn't solve it.
Message 13 of 13
gdeber
Technology Administrators
