Inventor 2023.1.1
I have an error showing up that the location of an external rule cannot be found (I imported my Application Options from another PC)
When I go to change it, the options are not there.
Any ideas?
Solved by BDCollett. Go to Solution.
Morning Ben - that makes things awkward 😂
It'll probably return if you reset the UI, but that removes all your hard work... Try adding it back into the "Zero Document" environment using "Customise UI":
@pcrawley wrote:Morning Ben - that makes things awkward 😂
Thanks Peter, I did try those things.. the option is not even showing up in the Ribbon options though..
Very odd.. I don't know where it went!
Oh, not good! And Reset Ribbon doesn't bring it back?
Attached is a copy of a "clean" 2023 ribbon to try. If I try it, I can see the "iLogic Configuration" option.
EDIT - Looks like you can't attach zipped .xml files to posts. I've renamed it to .txt
@pcrawley wrote:Oh, not good! And Reset Ribbon doesn't bring it back?
Still nothing. Might have to try a reinstall, something has gone a miss.
Ah ha... Tools > Add-Ins - Enable the iLogic add-in and restart Inventor.
That should save you a reinstall.
On 2022 Ilogic has there own import/export xml seperate to the applications object. You will have to have a file open and navigate to ilogic tab and export. This will export all the path settings to ilogic preference folder. This avoids having to remap manually the external rule locations.
@A.Acheson wrote:On 2022 Ilogic has there own import/export xml seperate to the applications object. You will have to have a file open and navigate to ilogic tab and export. This will export all the path settings to ilogic preference folder. This avoids having to remap manually the external rule locations.
I exported the options from Inventor 2023 and imported them into 2023. Nothing from 2022.
Hi! This could be an install issue. I would uninstall Inventor completely and reinstall it. Make sure all critical Windows updates are installed and .Net 4.8 is enabled.
Many thanks!
@johnsonshiue wrote:Hi! This could be an install issue. I would uninstall Inventor completely and reinstall it. Make sure all critical Windows updates are installed and .Net 4.8 is enabled.
Many thanks!
Hi Johnson,
It was working fine until I imported new Application Options. Strange issue.
I will reinstall.
same problem on Inventor 2024. Suddenly the iLogic Configuration desapears, and re-install doesn't solve it.
