I can't preview my Assembly constrains
Message 1 of 16
I don't know why the constrains preview isn't working. Out of nowhere these preview stop working. I've already checked the "Show Preview" option in "Place Constraint" window and it still doesn't work.
I also checked all options on the Assembly settings on the "Application Options". "Defer update" is off and "Enable relationship redundancy analysis" is off too.
I don't know how to fix this problem.
Replies (15)
Message 2 of 16
Cadmanto
Welcome to the forum.
If it worked before just recently and now it doesn't.  Have you tried restarting your PC/Inventor recently?
I have seen this simple action fix a lot of problems.  😉
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 16
Thanks for the response. I tried it but still doesn't work 😞
I don't know what did I disable, but out of nowhere it stop working.
Message 4 of 16
Cadmanto
It was worth a try.
See if you have below checked under the tools>options.  Having this checked prevents the assembly constraints preview from working.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 5 of 16
JDMather
It took me a while to set up a scenario where I could reproduce same behavior (not sure if it is the same issue though).
First, you have Show Preview checkmarked in Constraint.
*Second, it is normal to have selection filter on Component or Part Priority in assembly.
Third, if I go to Tools>Application Options>Colors tab an turn off Enable Prehighlight, then I can reproduce behavior.
___________________________________________________
*Second - but if I set selection priority to Faces and Edges it works.
So if this is the issue, you have two choices.
Set your Selection Priority to Faces and Edges
or
Enable Prehighlight.
I didn't notice before that this can also be toggled in the Selection Filters (Shift Right Click).
Message 6 of 16
Yeesss, thanks it was that.
I had Prehighlight disabled.
Now it works good.
Thank you very much.
Message 7 of 16
johnsonshiue
Hi! Assembly constraint preview is disabled when one of the selected components is either adaptive or derived. It is because the preview cannot be properly created when component geometry changes due to adaptive or derive.
Many thanks!
Software Test Engineer
Message 8 of 16
lena.talkhina
Welcome to the Autodesk Community!
Great to see you here on Inventor Forum.
Don't hesitate to accept  a solution if you find one.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 9 of 16
andy_mullen
I am having the same preview issue. I tried the solution above by changing my selection to priority to faces and edges. My highlight check boxes and preview check boxes were already checked. I also check the previous Defer update suggestion and that check box is unchecked.
Message 10 of 16
JDMather
@andy_mullen
Can you Attach an assembly that exhibits this behavior?
Message 11 of 16
johnsonshiue
Hi! Two possibilities. One of the selected components is either adaptive or derived (iPart member). This is a legacy behavior. The preview cannot properly show the end result due to the need to update the part geometry also. As a result, the preview is disabled.
Many thanks!
Message 12 of 16
paulmWABYD
Hello all, I'm having the same issue. "Show preview" is enabled, "defer update" is disabled, and "prehighlight" is enabled. Selection filter is typically on component priority. I've attached an assembly and a screen recording of me attempting to mate in that assembly. As you can see, the first mate offers a preview, and the second two do not. This has been persistent almost since the first day I started using 2023. Roughly 90-95% of my constraints do not preview. This is very challenging when trying to ascertain which side of a plane is the correct normal, etc. I very frequently have to close the constraint window and reverse the orientation of my last constraint.
Apologies for the lack of constraint window in the recording; Windows' built-in screen recorder can only record one window at a time.
Message 13 of 16
ethanfL67BY
Yeah, I'm having the same problem. None of my parts are adaptive either. It's frustrating.
Message 14 of 16
johnsonshiue
Hi Ethan,
Likely, the parts are derived parts or iParts. Please share an example here so that we can confirm. Or send the files in zip to me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Message 15 of 16
ethanfL67BY
Thanks for the reply. Once I run into an example I'll send a pack-n-go it over to you. The reasoning for the preview not working on my assembly is that I'm trying to make an adaptive part. But I think I have run into it not previewing before, but I can't remember what project I was working on.
Out of curiosity, how does it work with frame generator parts? Is it supposed to preview for those?
Message 16 of 16
johnsonshiue
Hi Ethan,
As long as it is not an adaptive part or a derive part, the assembly preview should work. Another possibility is that there is a preexisting failed constraint associated with the part you are trying to constrain. Please share an example that illustrates the behavior. There should be a logical explanation to the behavior.
Many thanks!
