How to View Translation Report (.XML) with Internet Explorer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I am using Windows 7 64-bit with Inventor 2012 and 2017 64-bit. When importing Mechanical Desktop 2009 files into Inventor 2012 I get a translation report with .xml file type that opens up with Internet Explorer, shown below (preferred).
Inventor 2012 Translation log (.xml) opened with Internet Explorer 11
When switching to Inventor 2017, on the same operating system, and running the Mechanical Desktop 2009 file import I get the same translation report file type (.xml) created. The difference is that when I click to open this file in Internet Explorer 11 I get code instead of the table report from 2012, shown below.
Has anyone had this issue, and if so how was it corrected so that you don't have to manually edit each file to be able to view it with Explorer (as shown in the first image)? Right now if I want to view the .xml file with Internet Explorer in table format I have to open the file with a text editor (Notepad) and add a line of code. The two images below show (TOP) the 2012 file that opens properly with Internet Explorer and (BOTTOM) the 2017 file that has a highlighted line of code added to allow it to open properly with Internet explorer.
Is there a config file or setting location within Inventor2017 or the Registry Editor that I can permanently change the translation report settings to create .xml reports that will open with Internet Explorer?
I'd appreciate any help,
Candace
