Error on Inventor Exit
I and several other people in my department often get the following error when exiting Inventor:
I tried searching around a bit but couldn't find anything. It doesn't seem to have any negative effects other than having to click through a couple more things before closing. Has anyone run into something like this?
Thanks!
Mark.Valenti
What version of inventor? Latest Service Packs installed? Is vault being used? Is it every time or with certain files? Hardware? Video card qualified?
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
SBix26
Looks to me as if an Add-in is not exiting gracefully.  Do you have any purchased or custom add-ins running?
Sam B
Inventor Professional 2018.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
johnsonshiue
Hi! The dialog indicates Inventor Connect Add-In is having issue. There are two options you can try. It looks like an install issue. You could simply disable Inventor Connect Add-In (go to Tools -> Add-Ins -> Inventor Connect -> uncheck two Load boxes). Or, you can do repair install to see if it works (Control Panel -> Programs and Features -> Autodesk Inventor Professional xxxx -> right-click -> Uninstall/Change -> Repair Install.
Many thanks!
Software Test Engineer
Thank you all for the suggestions. I do not see an Inventor Connect Add-in. I will attempt a repair on the installation on Monday morning.
I'm running Inventor 2017, version 4.2.0 on Windows 7. It does happen every time I close. Along the lines of it being an add-in related issue, I may try disabling some add-ins and closing to try to pinpoint the issue.
cmbronder
Hi: you need to right-click and select "Show Hidden Members" to see the Inventor Connected Design addin. If you are not using Inventor Design Shares, as Johnson suggested, uncheck the Load Automatically box.
How do you exit Inventor, for example, File->Exit Autodesk Inventor, or select the X in the upper-right, or by some other method?
Do you have any documents open when you Exit Inventor?
Thank you and apologies for the inconvenience.
kelly.young
Autodesk Support
Autodesk Support
@Anonymous were you able to disable some of the add-ins to get the message to cease?
Please select the Accept as Solution button if a post solves your issue or answers your question.
