How to shell a COMPLEX GENERATIVE DESIGN PART???
ZEBAS70
ZEBAS70
Hi I’m working on a really complex generative design part in inventor and I want to shell my solid part. I’ve tried everything!!!
I’ve tried shell
I've tried thicken/offset from solid and surface
I’ve tried free form thicken
but haven’t had any result. I don’t know what else to try!!!
I have the solid part, the surface and the freeform. Please help me !!!Shell with solid 01.PNGShell with solid 02.PNGThicken-Offset with solid.PNGThicken-Offset with Surface 01.PNGThicken-Offset with Surface 02.PNGFiles here
https://1drv.ms/f/s!AmbHaucZ8R_ug8dMGBk0uRqGkK6qdA
johnsonshiue
Hi! It took a quick look at the part. The original geometry was Mesh or Freeform, right? If yes, couldn't you do Thicken within Freeform?
Many thanks!
Software Test Engineer
ZEBAS70
Hi! Johnson thank you so much for your help
The original geometry was exported from another software and it was a solid part. Then I made it a mesh and then a freeform. Yes, I’ve tried the thicken command within Freeform, but I can only select one body the time!!!... I’ll add another image to the post. Thanks for your help !!!Thicken with Freeform 01.PNG
johnsonshiue
Hi! You will need to use Merge Edges command to merge those Freeform faces before you can thicken it.
Many thanks!
ZEBAS70
Hey I tried doing what you said it works !!!! nice...but I can't merge all the edges at one....I'll have to do it manually one by one and there are 616 surface bodies Smiley Indifferent .... is there another way I can merge all edges at once??Merge Edges Thicken.PNG
S_May
@ZEBAS70,
make small steps as in the pattern..
2018-06-05 11_18_13-Autodesk Inventor Professional 2019.png2018-06-05 11_34_07-Autodesk Inventor Professional 2019 - [PolyNURBS Block 3 Mirror Copy 8 - Freefor.png2018-06-05 11_34_32-Autodesk Inventor Professional 2019 - [PolyNURBS Block 3 Mirror Copy 8 - Freefor.png
ZEBAS70
Hi S_May thanks for your reply....yes I've tried working out small parts of the model Smiley LOL ..... I think that could be an option.... but I'm going to do some FEA after that so I don't know if the small parts will really be joint together...actually there are some sections where this error message show up !!! Thanks anywaySmall Steps in Thicken.PNG
