Creating a virtual intersection dimension with non linear elements
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
I see the answer to my question already here
https://forums.autodesk.com/t5/inventor-forum/intersection-dimension/m-p/8011663#M695921
before I even post it.
There is no solution, and my workaround seems to be the only way to do it. and an idea has already been posted.
I will post it anyway to get comments, and I will add my vote to the already existing idea.
How do you all place a dimension in idw between an "apparent intersection" point of a curve and a line,
and any other point. I am unable to figure out how to get this intersection without having to draw
an extra sketch on top of the view and draw the joining line in, dimensioning it, and then making it invisible.
I am convinced there is a much better way of doing this, which someone will show me
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Screencast will be displayed here after you click Post.
f078b7b0-23a4-4fe1-99e0-cdbb0e563258
 kelly.young has linked to the mentioned idea for clarity.
johnsonshiue
Hi Mike,
Indeed, Virtual Sharps or Extended Intersections are limited to linear line segments at the moment. You will need to add extension manually to create the true intersection before dimensioning.
Many thanks!
Software Test Engineer
MikeKovacik4928
Autodesk have sent me an email to ask if I got the answer I needed.
I got an answer, not the one I needed.
The answer I got is that it can't be done in Inventor, my workaround is the only way of doing it,
and the idea has been forwarded and not yet implemented, I have added my vote.
I can't mark this as an accepted solution, as it is a statement that a solution does not yet exist.
Michael Kovacik
