How to set Inventor IDW dimensions
cjfgns1003
cjfgns1003
Is there a way to set the "A" value for the distance between dimensions as shown below?
EdvinTailwind
To adjust the spacing between the drawing dimensions, see below. You seem to be looking for the D value
dave.cutting
If you select all of the dimensions, and then use the arrange command on the annotate toolbar, the dimension will be spaced out equally. You can do this on more than one side, or across multiple views.
The distance is set in the dimension style. If you want to modify the offset you'll have to modify it there.
Dave Cutting
