Inventor Forum
text of Degrees of Freedom too small in the graphic display
11 REPLIES 11
Message 1 of 12
gruen62UHC
660 Views, 11 Replies
gruen62UHC
I can hardly read the text and did not find a possibility to change the size of the text "90,000 grd" in the graphic display. Does someone have an idea where I can find the options for this? Please see attached screenshot.
11 REPLIES 11
Message 2 of 12
CCarreiras
in reply to: gruen62UHC
CCarreiras
Hi!
You can change it here to be slightly bigger:
CCarreiras
Hi!
CCarreiras
Message 3 of 12
gruen62UHC
in reply to: CCarreiras
gruen62UHC
Hello and thank you for the try,
unfortunately, this does not help. With the proposed option I can change the size of the text in the Part Browser, but the text in the graphic display is still not readable.
Best regards,
Karoline
Best regards,
Karoline
Message 4 of 12
CCarreiras
CCarreiras
Unfortunately, there's no other option.
You can ask for this at the Inventor Ideas Forum.
CCarreiras
CCarreiras
Message 5 of 12
gruen62UHC
gruen62UHC
May a Windows option overlap with it? I have a second example (please see attached screenshot) where Symbols  are extremely small. Does this lead to the solution?
Message 6 of 12
JDMather
JDMather
Maybe like this instead...
another advantage is the text is always right reading from any viewpoint.
Message 7 of 12
CCarreiras
CCarreiras
Yes, you can try to overlap windows resolution, try 150%.
Are you using a 4K monitor?
There's many threads about the 4K resolution, example:
https://forums.autodesk.com/t5/inventor-forum/4k-problems/td-p/5973622
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Ribbon-not-shown-c...
CCarreiras
CCarreiras
Message 8 of 12
Scott_Stubbington
I feel Application options -> General -> Annotation Scale
It will scale a number of things in Inventor's graphics window.
Message 9 of 12
JDMather
@Scott_Stubbington
Did you try it?
I did.
No effect.
@Scott_Stubbington
Did you try it?
I did.
No effect.
Message 10 of 12
gruen62UHC
in reply to: JDMather
gruen62UHC
Thank you for trying. I have to deal with other things at the moment and will try out every option at the latest on monday... sorry... I am very glad that you help me with that!
Message 11 of 12
Scott_Stubbington
@JDMather I did try it in a Part Environment with a Sketch visible and annotation scaled.
Having read your reply and replicated the situation I see it doesn't work.
@gruen62UHC Ignore what I've written, waste of time, sorry.
Message 12 of 12
gruen62UHC
gruen62UHC
Hello @JDMather,
thank you - this does help. I can read it perfect now.
Only the 0 degree does noch work properly and is marked in pink as usual (see screenshots). But I will live with it actually and marked your answer as solution.
--> So my first posted question did get a solution here - Thank you all!
Kind Regards,
Karoline
Hello @JDMather,
Kind Regards,
Karoline
