once again i have the need to dimension to the intersection of a centerline and a object line. why does inventor not give you the ability to create such a each dimension without having to sketch this, sketch that, project, da, da, da!
pro engineering, creo si by far leaps and bounds better than this program. dont't get me wrong creo has it's moments but making drawing it def has inventor beat. should be so simple. pick dimension tab (have options from point, line, intersection etc. choose what you need and "get ER done".!
i'll see how much luck fairs sketching unnecessary lines.
do you know if this has been turned into inventor as adding it to it's next update? how do you suggest things to be added?
