Loft problems
Loft problems
Loft problems
HI,
can someone please help? I seem to be having a issue with the loft feature for my canoe school project. all is fine until I try to add rails in the loft feature? I would like loft and rail the ipt. and then mirror it to make the while canoe.. any advice would be great!Screen Shot 2018-10-05 at 8.20.00 pm.pngScreen Shot 2018-10-05 at 8.19.18 pm.pngScreen Shot 2018-10-05 at 8.19.06 pm.png
TheCADWhisperer
No *.ipt file Attached?
hi there,
I have attached the full ipt for you to have a look over...
thanks for taking the time to help out!
IgorMir
Hi Wil,
You have to create a loft between the deck line and the keel line. Select them both for lofting. And the midship rib line is a Rail. Here is a file in IV2018 format.
Cheers,
Igor.
P..S. Unconstrained sketches are a big No-No in any parametric modeller, let alone the Inventor. Make sure the sketches in your design are always fully defined.
Web: www.meqc.com.au
johnsonshiue
Hi! When Loft does not work for you, you may want to try Boundary Patch. Usually, you will get better result than Loft when Loft fails.
Many thanks!
Software Test Engineer
hi Igor,
I have inventor 2016 so I seem unable to open your attachment.. thanks for taking the time to help out though!
