How to put perimeters of face from one part to another part?
Message 1 of 8
Hey guys I just started using Inventor so this may be an easy question. But essentially I need to place the border edge perimeter from Part ONE unto Part TWO so I can make a hole with the shape of the first part. How do I do this? Do I create a derived part? And if so how would I do this.
 Part 2
Part 2.PNGPart 1.PNGPart ONE
-Thank you
Replies (7)
Message 2 of 8
JDMather
That would be one easy way - in Part2 Derive Component Part1 as Composite Surface.
An easier way for a beginner might to be Multi-body solids within a single part file then push out the assembly.
Message 3 of 8
johnsonshiue
Hi! There are mainly two ways to do that. You can derive PartB to PartA as a separate solid body. Then use Direct Edit or Move Bodies command to relocate the derived body.
The other way to do that is to put the two parts in an assembly. Constrain them properly. Then edit PartA in place. Use Copy Objects command -> pick PartB.
Many thanks!
Software Test Engineer
Message 4 of 8
jhackney1972
There are many ways to do this.  I think one of the easiest is just to copy the sketch from the master and paste it into the one you want the new feature.  You can edit the sketch by changing constraints or dimensions to adjust its location and size before making the feature.  Take a look at the screencast.
John Hackney, Retired
Message 5 of 8
I tried this but the issues seems to be that Part 1 is a step file so i cant find the copy sketch option as the sketch doesnt show up in the tree.
Message 6 of 8
jhackney1972
That will kill my method, you did not mention that this was a STEP file.  Drop back and use one of the other methods proposed.
Message 7 of 8
Yeah I'm sorry I forgot to mention that. Didnt realize how important it would be. But either way i used your method. I just projected the geometry on a new sketch on the surface of the step file then copied that sketch. Thank you very much.
Message 8 of 8
jhackney1972
That was smart on your part creating the new projected sketch.  If you have a solution, please mark your question as solved to remove it off of the forum question board.
