Hi all.
Im making animations where i need to animate waterspray from a nozzle, but how?
I have tried making the waterspray transparent, but it still looks "flat".
Anybody got any ideas? 🙂
Thx for your time.
Hi all.
Thx for your time.
Solved by Ray_Feiler. Go to Solution.
model a cone instead of a sector
http://mathcentral.uregina.ca/QQ/database/QQ.09.17/h/jessica2.html
It is flat fan nozzles, not hollow cone nozzles 🙂
What about just creating a triangular model that represents the flat water spray. Then change the material to water.
This thread might give you some ideas as well.
https://forums.autodesk.com/t5/autocad-forum/water-rendering/td-p/6068752
Another thought would be to model it in Inventor, then animate it in 3D Max or Maya.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Inventor Pro 2018
@Anonymous model with Water Bubbles style applied.
Thx for your input 😄
I fear it will look too much like a cone, and not the flat fan nozzle spray, but i will try to play around with it.
Any other suggestions?
edited
In these cases I use a custom material with opacity maps
Admaiora
Admaiora
Thx a lot for your inspiration all 🙂
I ended up with the following solution.
It's not great, but better than the initial solution.
