how to make stick text that i can cam to
This widget could not be displayed.
i would like to make simple "stick" text that i can cam to, does anyone know how to do this. i currently made stick letters in autocad, then have to arrange them to make whatever part number out of them, then import into inventor.
this is very time consuming but it is what our customer wants.
S_May
@Anonymous ,
please show us a pattern, and where the text should be inserted
If you look i have stick text on top of the model. I have attached the model as well.P30911.JPG
I found a video with a  add in the looks like just what i want, however i cannot find said add on. Is this still available?Text tool Snip of video.JPG
mcgyvr
I just use "Simplex" font and then engrave it with the HSM "Trace" function and set "Stock to Leave (Axial)" to -.015 (or whatever depth I want it engraved)
Works perfect
Thanks, but that does not work the way i want it too. The video i found show him making cutter path exactly the way i would like. Just do not know where to get that add in, it does not show up in AUTODESK apps.
