Inventor Forum
.ide file dimension loss
10 REPLIES 10
Message 1 of 11
345 Views, 10 Replies
I create a .ide file which when first saved from the model has extrusion depth which can be automatically added to the drawing - this is great!
BUT if you edit said .ide file (do something or don't actually do anything) and save it the depth info is lost...     not so good.
 Any work arounds please
Tim
Tags (2)
10 REPLIES 10
Message 2 of 11
Cadmanto
Is this depth dimension a variable?  Meaning is it associative to another feature?
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 11
in reply to: Cadmanto
No the depth is not a variable or even variable. It's just a fixed extrusion depth of a adjustable bore. Which I then wish to produce a 2D drawing.
Message 4 of 11
I have found by trail and error as a search of all the help has turned up nothing. That by having a sheared sketch which has multi adjustable bore diameters on it I can get the dims from the .ide file as long as this sketch is first one. But if I wish to set up a table driven ifeature you have to edit the .ide file! This is when the depth info disappears.
Message 5 of 11
Cadmanto
Is the depth value specified in the ide table?
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 6 of 11
No the depths are to remain fixed
Message 7 of 11
Cadmanto
Regardless whether they are fixed or not, I would put them in the table anyway and see if this resolves the issue.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 8 of 11
They still disappear. It seams as you edit the ide file the only dims that are retained are those that are only on the 1st sketch all the others are gone.
Message 9 of 11
johnsonshiue
Hi Tim,
Could you share the ipt file (the iFeature source part file) and the ide file here? Or you can send them to me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 10 of 11
in reply to: johnsonshiue
Problem is identified as a bug - no quick fix. (Autodesk is looking into it)
Message 11 of 11
johnsonshiue
Hi! The defect was reported as INVGEN-26601.
Many thanks!
Technology Administrators
