how to draw or convert line in sketch (part) to polyline.
Can you explain your need for a polyline?
Why would it be useful in Inventor?
(it is not possible in current release)
A sketch block might give you some functionality similar to a polyline.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Hi all,
As always digging old post is my hobby...
FYI, i needed it today to be able to estimate the perimeter of my assembly. (whithout pain plz!)
Frankly asking why a polyline would be usefull is upsetting/insulting imo. Its called a drawing and it contain more than one line so might as well help the process and eliminate the need to constraint!
Also your link is not usefull at all... have a nice day
Create a model using the profile you showed in your attachment. If you just extrude it, see below and you will get your perimeter without needing a polyline.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
sketch(part) is not sketch in .idw? ok another day maybe
still the matter of the pline in .idw should be adressed
No.
Inventor don't use or need Polyline. All profiles behave like "polyline".
If you need polyline, use AutoCAD.
Measure tool in Inventor will get the info you need:
You said you wanted the polyline to give you the perimeter. If you are just looking to sketch in the idw then yes, @Frederick_Law is correct get Autocad. What I showed you is in the model. That is where what you are looking for what you want in the perimeter.
Inventor Pro 2018
As you have found, Inventor does not use polylines. Would a spline get you close-enough?
The region properties command needs one or more closed loops.
The properties command only addresses line types, line weights, and colors.
What happens if you use an Inventor dwg and open it up in AutoCAD?
Steve Walton
the total lenght of a path i suppose
i need to export my assembly in autocad and create a polyline, right click, proprety
Then create your inventor drawing, maybe tie the perimeter into a property and link into the drawing. Then export to an Autocad .dwg.
https://forums.autodesk.com/t5/inventor-forum/loop-length-in-drawing/td-p/7769886
Inventor Pro 2018
Faster then export and measure in AutoCAD.
Even faster once you change it.
Change dimension to driven and you can drag it to change.
hi folks!!
Is there any way to do this measurement of a chain easier?? Without exporting to AutoCAD or making something so crasy using parameters like above? I lost myself by clicking in those lines and i forget where I started...
Measure loop, can you Attach your *.ipt file here?
This is an old thread and the technique has changed.
Only requires a single click...
But this profile is open, i cant measure with region properties like you said. Even if I close the sketch with a construction line i still cant measure that lenght
1512.047-67.268=?
Hi! The length of connected line segments can be measured. You don't need to add them up. Go to Measure tool -> mouse-hover a line -> right-click -> Loop. The tool will show the total length of the loop.
Many thanks!
i'd rather not make any calculations or changing line styles but ok, that works... Thanks for helping guys
