Inventor Forum
how to make polyline in sketch(part) in invetor
19 REPLIES 19
Message 1 of 20
rgruychev
4178 Views, 19 Replies
rgruychev
how to draw or convert line in sketch (part) to polyline.
19 REPLIES 19
Message 2 of 20
JDMather
in reply to: rgruychev
JDMather
Can you explain your need for a polyline?
Why would it be useful in Inventor?
(it is not possible in current release)
A sketch block might give you some functionality similar to a polyline.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Message 3 of 20
maximeURGVK
in reply to: JDMather
maximeURGVK
Hi all,
As always digging old post is my hobby...
FYI, i needed it today to be able to estimate the perimeter of my assembly. (whithout pain plz!)
Frankly asking why a polyline would be usefull is upsetting/insulting imo. Its called a drawing and it contain more than one line so might as well help the process and eliminate the need to constraint!
Also your link is not usefull at all... have a nice day
Hi all,
Message 4 of 20
Cadmanto
in reply to: maximeURGVK
Cadmanto
Create a model using the profile you showed in your attachment.  If you just extrude it, see below and you will get your perimeter without needing a polyline.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 5 of 20
maximeURGVK
in reply to: Cadmanto
maximeURGVK
sketch(part) is not sketch in .idw? ok another day maybe
still the matter of the pline in .idw should be adressed
Message 6 of 20
Frederick_Law
Frederick_Law
No.
Inventor don't use or need Polyline.  All profiles behave like "polyline".
If you need polyline, use AutoCAD.
Measure tool in Inventor will get the info you need:
No.
Message 7 of 20
maximeURGVK
in reply to: Frederick_Law
maximeURGVK
this is what i get both in idw or in par if im not having a closed loop
Message 8 of 20
Cadmanto
Cadmanto
You said you wanted the polyline to give you the perimeter.  If you are just looking to sketch in the idw then yes, @Frederick_Law  is correct get Autocad.  What I showed you is in the model.  That is where what you are looking for what you want in the perimeter.
Inventor Pro 2018
Best Regards,
Scott McFadden
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 9 of 20
swalton
swalton
As you have found, Inventor does not use polylines.  Would a spline get you close-enough?
The region properties command needs one or more closed loops.
The properties command only addresses line types, line weights, and colors.
What happens if you use an Inventor dwg and open it up in AutoCAD?
Steve Walton
Inventor 2024
Vault Professional 2024
Steve Walton
Inventor 2024
Message 10 of 20
maximeURGVK
maximeURGVK
the total lenght of a path i suppose
i need to export my assembly in autocad and create a polyline, right click, proprety
Message 11 of 20
Cadmanto
Cadmanto
Then create your inventor drawing, maybe tie the perimeter into a property and link into the drawing.  Then export to an Autocad .dwg.
https://forums.autodesk.com/t5/inventor-forum/loop-length-in-drawing/td-p/7769886
Inventor Pro 2018
Best Regards,
Scott McFadden
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 12 of 20
Frederick_Law
Frederick_Law
Message 13 of 20
maximeURGVK
maximeURGVK
haha verry cute but not fast enuf for me
Message 14 of 20
Frederick_Law
Frederick_Law
Faster then export and measure in AutoCAD.
Even faster once you change it.
Change dimension to driven and you can drag it to change.
Message 15 of 20
fabricio.pandolfoX3CTG
hi folks!!
Is there any way to do this measurement of a chain easier?? Without exporting to AutoCAD or making something so crasy using parameters like above? I lost myself by clicking in those lines and i forget where I started...
hi folks!!
Message 16 of 20
JDMather
Measure loop, can you Attach your *.ipt file here?
This is an old thread and the technique has changed.
Only requires a single click...
Message 17 of 20
But this profile is open, i cant measure with region properties like you said. Even if I close the sketch with a construction line i still cant measure that lenght
Message 18 of 20
JDMather
1512.047-67.268=?
1512.047-67.268=?
Message 19 of 20
johnsonshiue
johnsonshiue
Hi! The length of connected line segments can be measured. You don't need to add them up. Go to Measure tool -> mouse-hover a line -> right-click -> Loop. The tool will show the total length of the loop.
Many thanks!
Software Test Engineer
Many thanks!
Message 20 of 20
i'd rather not make any calculations or changing line styles but ok, that works... Thanks for helping guys
