How to import external Pack and Go?
pawel.pietraczyk
pawel.pietraczyk
Hello!
Disclaimer: I never worked in Inventor, total newbie.
I have received a Pack & Go assembly (see attached screenshot) - how do I go about opening and using this?
The task that I have been given is to make a "lightweight" version of this to export via NWC / STEP to our 3d modelling software - equipment from the Pack&Go is just part of a very big assembly line, when I import the STEP given by the supplier I have a massive performance drop, as the supplier just exports to STEP everything - for the 3d modelling of the entire production line I just need the outer shell.
Thank you for your help 🙂
mgeurts
Go to Workspace folder, straight or via Inventor, find 009304-5019.iam and open.
Inventor Professional 2021
3DS Max 2022
Win 10
bradeneuropeArthur
First open the ipj file in that location with inventor (Double click), or choose in Inventor this project file.
Than goto the Workspace folder and open the file.
All relations should be ok now due to the use of th ipj file.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
TheCADWhisperer
Can you Attach the zipped Pack and Go here?
pawel.pietraczyk
Sorry, it's confidential 😕
kevin_j_morin
SMD
