How to give torsional stiffness to a spring in FEA analysis?
Message 1 of 9
Heey!
I am doing an fea analysis in Autodesk Inventor.
And I want to give a spring in my design a torsional stiffness of 750 Nm/rad, how can I do that?
I hope that someone can help me
Replies (8)
Message 2 of 9
JDMather
Attach file(s) here.
Message 3 of 9
So, between the hinges there must be a spring with a torsional stiffness of 750 Nm/rad
Message 4 of 9
Owh and here is the assembly
Message 5 of 9
JDMather
Carbon Fiber is not isotropic.
What is your purpose for doing this analysis - specifically, what do you want to know?
Message 6 of 9
I want to determine the natural frequency of the beam.
There is a torsion spring between the hinge leafe and beam.
I want to give the spring a torsional stiffness of 750 Nm/rad, but in Inventor I only can give the spring a normal or tangential stiffness
Message 7 of 9
Message 8 of 9
lena.talkhina
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 9 of 9
johnsonshiue
Hi! I don't believe you can assign torsion stiffness or torsion constant in FEA. It is because the property depends on shape. It is a calculated property, not an assigned property like Young's modulus or density.
Many thanks!
Software Test Engineer
