AUTOCAD STEELWORK
AUTOCAD STEELWORK
Keith.Challinor3761
Message 1 of 10
AUTOCAD STEELWORK
Keith.Challinor3761
we work with clients who produce a steelwork frame upon which we site our equipment
the steelwork is produced in Autocad and given to us as a 3D model (dwg)
some of the steelwork is solids some are meshes that will not convert to solid and so cant be imported to Inventor
does any one know of any way that the steel work can be converted to be of use in inventor
i have tried export to STL STP SAT etc but the meshes are the problem has anyone written a shrink wrap for AutoCAD
Replies (9)
Message 2 of 10
JDMather
@Keith.Challinor3761 wrote:
... some are meshes that will not convert to solid and so cant be imported to Inventor
STL???
Attach an example *.dwg file here.
Message 3 of 10
Keith.Challinor3761
Yes tried sat stl stp and few more
Message 4 of 10
JDMather
stl is rubbish???
Not appropriate file format for what you describe.
Attach your dwg file here and end all doubt.
Message 5 of 10
MICHAEL.JONES.AMCE
Do you know if the client is utilizing Advance Steel to create the steel structures?
Message 6 of 10
johnsonshiue
Hi Keith,
Inventor has some mesh modeling workflows, though not comprehensive.  You can import mesh data in stl, obj, STEP, and other formats. Then you can create geometry based on the mesh. Or, you can create drawing views for the mesh object and annotate the views.
Please share an example here so forum experts can take a look and help find the best workflow for you.
Many thanks!
Software Test Engineer
Message 7 of 10
Keith.Challinor3761
i have asked what they are using and am told AUTOCAD i suspect that they are using advanced steel as i cant imagine anyone using just Vanilla AutoCAD for this work
Message 8 of 10
MICHAEL.JONES.AMCE
If they're using Advance Steel...they have some options for exporting other than a .dwg file.
 Also found this forum posting discussing workflows for IFC files into Inventor.
The post discusses Cross-Manager a stand-alone (purchased) package to convert various CAD files.
Message 9 of 10
lena.talkhina
Hello @Keith.Challinor3761 !
Just guessing,
are they use Advance steel for Revit or for AutoCAD?
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 10 of 10
Keith.Challinor3761
I would think ADVANCED STEEL FOR AUTOCAD , that being the case what would be the best way for them to export for use in INVENTOR?
