IFC files in to Inventor 2018
MariaManuela
Advisor Advisor
Message 1 of 10
MariaManuela
Hi All,
After reading some information on the web i think there is no solution to my (customer) question....but here it goes:
What is the best method (if there is) to import BIM  IFC files in to Inventor 2018?
I already tested open in AutoCAD, export as step file, but without success.
What the customer needs is to just use the IFC as a solid in Inventor to work over it.
Open in Navisworks:
Thanks a lot
Replies (9)
Message 2 of 10
mcgyvr
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Import...
Can they get a step file instead of IFC to work with? I'd think those programs have other export options that Inventor can work with..
You might also be able to find an IFC viewer that can export STEP files or similar..
Show your support for adding that functionality in the future..
https://forums.autodesk.com/t5/inventor-ideas/ability-to-import-ifc-ifc-files-into-inventor/idi-p/58...
Message 3 of 10
Robert_Benjamins
We use the 'FZKViewer'-program from Karlsruher Institut für Technologie (KIT) to convert the IFC files.
FZKViewer can open an IFC-file and export it to STEP.
You can download the program here:
https://www.iai.kit.edu/1302.php
I hope the program can work for you as a workaround.
Kind regards,
Robert Benjamins
Inventor 2024
Message 4 of 10
MariaManuela
Thanks you.
Yes, i already voted on that idea when i started researching this issue.
Thank you for your suggestion.
Manuela
Message 5 of 10
MariaManuela
Hi Robert,
I really like your suggestion.
I downloaded it, tried it as a step but it does not work. When i open in Inventor 2018 nothing appears.
But when i export as STL it works perfectly and i can even work on the mesh faces.
Looks good to me but now i'll wait for the customer's opinion.
Thans very much!
Manuela
Message 6 of 10
jimmy.haryanto
Observer
Observer
Any solutions if I am using inventor 2013?
I try to download the software mentioned, but it wont let me run as its saying missing dll files.
Message 7 of 10
Bumping this post since I'm having a similar problem.
We have a large scale IFC model made with Autocad - Magicad extension that opens up nicely on Navisworks.
Our partner needs this in .stp -format, and so far we haven't been able to provide them what they need.
IFC import in Inventor 2019 would be highly needed!
Message 8 of 10
hvandeweerd
Another solution:
Download Ifcconvert from http://ifcopenshell.org/ifcconvert
You can convert an .IFC to .STP but it takes a very long time for large assemblies. Better convert it to .OBJ and import it directly in Inventor,  Check for the right scale.  Use "options" button while opening the .OBJ in Inventor.
The standard unit for .IFC is Meters.
(I am using Inventor 2020)
Message 9 of 10
You can also use CrossManager to do that: https://www.datakit.com/en/cross_manager.php
Message 10 of 10
maxim.teleguz
12/15/2021 - tested and worked with 2020 inventor, rename .ifc file to .step and now open in inventor and it will open flawlessly.
