Frame Generator Issue
sMuldowneyYLYE8
Message 1 of 12
sMuldowneyYLYE8
I am trying to use frame generator and when I pick my sketch to layout the frame. I hit apply and they never show up. Is there a setting or is there a issue with frame generator. My co-worker, does exactly the same thing I do and his frame shows up.
Replies (11)
Message 2 of 12
Mark.Lancaster
@sMuldowneyYLYE8
Welcome to the Autodesk Community..
What Inventor version?
Are you seeing any messages?  Does it appear to lock up?  Do you have the preview option selected?
Mark Lancaster
Message 3 of 12
sMuldowneyYLYE8
Inventor 2019 And no messages and does not lock up and when I pick the sketch lines it shows the preview of the frame.
Message 4 of 12
Mark.Lancaster
@sMuldowneyYLYE8
And what happens when you select apply or ok?  Nothing?
Mark Lancaster
Message 5 of 12
sMuldowneyYLYE8
Nothing it pauses as if it is doing something, but then nothing happens, goes back to the frame generator menu
Message 6 of 12
Mark.Lancaster
@sMuldowneyYLYE8
When it happens, do the following
ALT+SPACEBAR
M key
LEFT or RIGHT arrow key
Move mouse..   Anything trapped to it?
Are you using Inv 2019 under Win 10?  If so what version of Win 10 is it?
Mark Lancaster
Message 7 of 12
sMuldowneyYLYE8
I hit ALT+SPACEBAR the menu on top has numbers show up. M key brings up Measure menu, LEFT or RIGHT arrow key just moves the sketch I am using for the frame layout. Move mouse and nothing is trapped.
Message 8 of 12
sMuldowneyYLYE8
Windows 10 Pro
Message 9 of 12
JDMather
@sMuldowneyYLYE8 wrote:
Inventor 2019
Install Updates for 2019
Message 10 of 12
johnsonshiue
Hi! Like JD mentioned here, you may want to install 2019.4 update followed by 2019.4.4 update. Also, make sure all critical Windows updates are installed.
Many thanks!
Software Test Engineer
Message 11 of 12
MoshiurRashid
Apart from software issues, frame generator sometimes unable to create frame if there is arcs and the profile is bigger with respect to the arc. Please check that also.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 12 of 12
lena.talkhina
Hello @sMuldowneyYLYE8  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
