How to generate a point without a sketch?
manuel_reitmeier
manuel_reitmeier
Community Visitor
Community Visitor
Hello Community?
I want to create a 3D sketch for a welding frame. To achive maximum flexibility in the process i want to create 3d points without any references or without a 3d sketch - just the coordinates and connect them later on. is this possible in inventor?
thanks in advance!
kacper.suchomski
Hi
Check Work points.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-045A1EA5-DCEF-4998-B832-DB2B2C8CF7F5
BTW. Sketches do not eliminate flexibility.
Kacper Suchomski
Sergio.D.Suárez
3 Non-coplanar points in space could generate a pyramid with a triangular base. With this approach you could create a solid that represents this body, and with this you could use the Frame Generator to achieve what you are looking for, without needing to have a sketch, but better yet a reference solid to anchor what you need.
In the video I show you a basic example, and at the end I show you how to create workpoints in space, these points could be part of an adaptive piece and be adaptive workpoints later, and vary randomly. I don't really understand what you're trying to achieve, so I made a descriptive video of both methods.
As a personal recommendation, I would tell you that using sketch is always reliable, just avoid using sketch3D in skeletons, it is preferable to use 2 or 3 2D sketches that are much safer to control than a 3D sketch
Best Regards!
[video]
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
cidhelp
Hello @manuel_reitmeier ,
you can create fixed workpoints by entering x/y/z-values (pick red/green/blue arrowhead and type value).
johnsonshiue
Hi! Another option is to create a UCS. It is a user-defined coordinate system. As the origin folder, it also contains the origin point, axes and planes.
Many thanks!
Software Test Engineer
