Angle Constrain
Angle Constrain
vandiverdiantrisdianto
Angle Constrain
Hello everyone! I want to do like this with constrain, can I?(on the picture)
1. I want the cylinder axle inside the square hollow
2. I want the wheel attach to the frame edge
JDMather
Yes.
Sergio.D.Suárez
Hi, I hope you are doing good.
1 - The square hole should have a work axis in its center, then you would create a cylinder axis constraint with a square axis
2 - The wheel must have an axis from which to rotate. The same previous method applies, you must have two working axes available in each piece
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
James_Willo
If your box section was drawn correctly around the origin, you can even use the Inventor origin axis of the box section to mate with your axle. The axis doesn't have to be visible to mate to it, so don't fall into the trap of making everything visible, just click it in the browser.
James W
Inventor UX Designer
