Need a little help on curve paths using sweep/loft to connect two profiles
joshuapaulsarigumba29
Observer Observer
Observer
Observer
Hello, I am trying to build an aircraft but there is a specific part where I am having trouble with how to connect two profiles with curve in between
I have tried using sweep(which has shown almost what I want but it is still not as exact as it should be)
I have tried using loft(which just makes it a straight path with no curve)
Is there a way using these two tools to make the curve?
Sergio.D.Suárez
Hi, I hope you are doing good. You have to use loft in my opinion.
A recommendation, your aircraft is symmetrical, you should model only half, then in the end a mirror will do the rest.
The loft must be made with several profiles, and with a condition of tangency so that it maintains a smooth transition.
Remember to model guide curves to achieve a good transition between the profiles, and here an important point, make sure that each guide curve intersects the profiles, if you do not place the match it will give you a lot of headaches. The loft is an excellent tool, I prefer not to model the piece for you, so that you can practice over and over again until you master it perfectly.
Best Regards!!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
johnsonshiue
Hi! I believe you are trying to reverse-engineer a model airplane. I don't think you will get a good design by basing off the section sketches. You may get close, but you will run into issues very quickly. The model will not be editable easily. I think you should study the model's design intent and try to find the logical features to recreate the geometry. Ignore the detail features first and start with a simple shape. Add the detail features gradually. This is how feature-based parametric solid modeling should work.
Many thanks!
Software Test Engineer
