Inventor Forum
How to Flat pattern contour rolled circular hollow tube after using sculpt feature?
8 REPLIES 8
Message 1 of 9
jimmyshettyr
396 Views, 8 Replies
I have done a circular rolled part from hollow tube using counter roll feature. After this I have used the sculpt feature to trim the part. Now after using sculpt feature I am not able to do the flat pattern for this .
8 REPLIES 8
Message 2 of 9
What version of Inventor are you using??
Thomas.
Thomas Savage
Design Engineer
Message 3 of 9
jimmyshettyr
in reply to: jimmyshettyr
2023
Message 4 of 9
Thank you,
Can I ask what you are trying to achieve.
Is this tube in which you are bending round then putting a cut out in to slide the other tube in?
Why are you doing this as a flat pattern part?
Thank you,
Thomas
Thomas Savage
Design Engineer
Message 5 of 9
This is a wrap around template for Tube cutting.
Message 6 of 9
Hi
If something cannot be done conventionally, use the Unwrap tool.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 7 of 9
johnsonshiue
Hi! Unfortunately, this is a limitation in Inventor Sheet Metal Flat Pattern. Due to the Sculpt cut, the Contour Roll lost the planar reference to unroll and unfold. As a result, there is no place to start the unfolding process. Unwrap is your best bet in this case.
Many thanks!
Software Test Engineer
Message 8 of 9
Hi Johnson
I understand that sculpt is not for sheet metal (though Inventor's algorithms could be more flexible).
But I don't understand why it can't be cut perpendicularly in order to keep all curvatures and correct surfaces. This looks like an bug to me.
Kacper Suchomski
Message 9 of 9
johnsonshiue
Hi! This has nothing to do with Sculpt per-se. It is more about the cut removing all planar reference geometry, which is needed to unfold.
Many thanks!
Technology Administrators
