Dock model browser on left
carlRLFP5
Message 1 of 10
carlRLFP5
How do you dock the model browser on the left? Accidentally moved it wont go back
Replies (9)
Message 2 of 10
gcoombridge
Drag it by the bar at the top as hard to the left as you can then release. If using several monitors place inventor on the far left screen first I guess
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 3 of 10
carlRLFP5
Doesnt work.
Message 4 of 10
gcoombridge
Mmm I'm using inventor 2021.1 and it does for me.. What version are you using?
Message 5 of 10
mcgyvr
What specifically isn't working?
You can't move it at all?
Its just not "locking" into place?
Are you running dual monitors?
What version of Inventor are you using?
Have you installed all updates?
Have you tried the Inventor Reset Utility?
Message 6 of 10
johnsonshiue
Hi! Like experts had mentioned, it should work. Something was wrong with some settings. Try this real quick. Go to All Programs -> Autodesk -> Inventor 20xx -> Tools -> Inventor Reset Utility. Reset all settings back to install default.
Does it work now?
Many thanks!
Software Test Engineer
Message 7 of 10
ethan_howardMMXXV
@johnsonshiue Double-click the top of the side browser and it will dock.
Can the side browser be "pinned", "grounded", or "nailed" in position so I don't continue to accidentally undock? Thank you.
Autodesk Inventor Professional 2024
64-Bit Edition
Build 153, 2024.0.1 Update - Date: Tue 05/09/2023
Autodesk Vault Professional 2024
Build 29.0.68.0
2024.0.1 Update
Message 8 of 10
johnsonshiue
Hi Ethan,
I am sorry I am not aware of a setting to ground the browser. It is always dockable.
Many thanks!
Message 9 of 10
c_tizaoui
Community Visitor
Community Visitor
Try: View --> Reset UI Layout
Message 10 of 10
ewempe
Observer
Observer
Thank you it works great and fixed the problem.
Grateful user.
