I have a model from another company with a sheetmetal punch in it.
I dont have the feature selves.
How can I create a feature out of it or how can I get the feature from it.
Is there something available for that
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Solved by admaiora. Go to Solution.
On the Manage tab, under Author... use Extract iFeature tool.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi @CGBenner
Since it is already used in the model it is already a feature.
But I don't have the mother-file the basis!
Arthur Knoors
If you extract the ifeature, you can save it to your Feature catalog for future use.
Chris Benner
I cannot extract the i-feature.
It is only possible when it is not an I-feature.
this is in the model tree.
I want to have it as punch tool again, but how?
Arthur Knoors
What happens when you try to use the Extract tool?
Chris Benner
only the sketches are in then and not the volume!
it is a cut and than adds material like a normal puch.
Arthur Knoors
I presume that you can't do nothing but redo again all the features, then extract them.
Admaiora
is that really true, since it is very complex to re-produce!
Arthur Knoors
Can you share the part file here?
Chris Benner
Here it is
Arthur Knoors
From my point of view, I confirm, you can't.
You are looking fot "Crossbreak Punch Tool.ide" that is not present in your machine
Admaiora
@admaiora Correct!
Arthur Knoors
Looking at the file, I would agree with @admaiora
This does not seem possible.
Chris Benner
