How to? (Dimension questions)
drawingsCHR7R
drawingsCHR7R
Hi all,
I would like to know if the following can be done (Hopefully without iLogic):
Can you set your dimension style so that when you dimension a line that has no decimals it will show only the whole number, but when you dimension a line that DOES have decimals it shows the decimals to whatever point you have specified, in this case to 2 decimals?
CGBenner
@drawingsCHR7R
You can control this in your Dimension style by unchecking Display Trailing Zeros, and setting the precision to two decimals.  With this, 1" would display as just 1 in your dimension, while 1 1/2" would display as 1.5
Is this what you're after?
Chris Benner
JDMather
What I do is set up Dimension Styles for 0   .1   .12 and .123 decimal places.
Then I dimension at least one of each style as needed.
Then I go through and dimension ALL other dimensions with the most common style.
Finally, I go back and Match Properties the intended style on the previous step.
This requires discipline though in not accidently missing a change.
Oh wait a minute.
Are you referring to sketch dimensioning or to drawing dimensioning?
drawingsCHR7R
I am referring to drawing dimensions on an idw.
drawingsCHR7R
Would 1.05" display as 1" or as 1.05"?
CGBenner
@drawingsCHR7R
With precision set to 2 decimals, it should display as 1.05 since the second place is not a zero.
Chris Benner
drawingsCHR7R
Worked perfectly, thanks a bunch!
