- Mute
- Permalink
- Report
Hi all,
I would like to know if the following can be done (Hopefully without iLogic):
Can you set your dimension style so that when you dimension a line that has no decimals it will show only the whole number, but when you dimension a line that DOES have decimals it shows the decimals to whatever point you have specified, in this case to 2 decimals?
