How to detach an object from an array... (if that is even possible)
oransen
Message 1 of 12
oransen
I'm more of a programmer than a user so maybe this is a stupid question, but here goes:
Is it possible to detach an object from a linear array, so that the rest of the array remains, but the detached object can be moved into a slightly non-array position?
Replies (11)
Message 2 of 12
CCarreiras
HI!
No.
You have to suppress the object.
Place another equal object and position it like you need.
CCarreiras
Message 3 of 12
-niels-
Which version of inventor?
For sketches:
In Inventor 2017 you have sketch driven patterns that would allow for elements to have different positions.
In previous versions you'll have to suppress and create a new instance, like @CCarreiras mentioned.
For assemblies:
If you want a single element to be moved around, you can expand the pattern and select the element you want moveable, right-click on it and select "independent":
Hope that helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 12
Rob67ert
If you expand the feature you see all the occurrence. Right click on one of them and select suppress.
Then just place a new sketch of the object you like at a different position.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 5 of 12
oransen
As usual I discovered a solution as soon as I posted this. Right click on the object in the array and click on "free rotate" or "free move". Inventor 2015
Message 6 of 12
oransen
In Inventor 2015 I get "Free Rotate" and  "Free Move" but not "independent"...
Message 7 of 12
-niels-
Make sure they don't snap back in to place if you update the model when using "free move"... i don't think it's a permanent function.
You could use the move body / direct edit tools though.
(Assuming you want this for sketches / .ipt, not assemblies... still a bit confused about that.)
Niels van der Veer
The Netherlands
Message 8 of 12
oransen
You're right. If I save and re-open the assembly the free move has vanished and the part is back in place.
Message 9 of 12
oransen
I'm doing it for part arrays inside assemblies. I think the suppress and insert another part is the best solution...
Message 10 of 12
CCarreiras
Free move and free rotate are always temporary situation.
You marked the correct answers as solution, why you are using a different process?! 🙂
CCarreiras
Message 11 of 12
oransen
"You marked the correct answers as solution, why you are using a different process?! :)"
I don't understand your statment. I think that suppress and insert a new part is the correct solution...
Message 12 of 12
CCarreiras
Suppress and insert a new part is the correct solution.
The free move and rotate is wrong.
CCarreiras
