How to merge multiple faces on a solid body surface into a single face?
DScott100
DScott100
Hello Inventor Community,
I've searched the forum and cannot find a solution to this problem.  I've also searched the commands within Inventor and Fusion360, no luck.
Is there a way to merge multiple faces of a solid body surface into a single face?  I am starting with an imported model (that I have manipulated and imported from a laser scan.stl file) and want to work with a single outer face as I progress the design forward.
Any help/guidance would be appreciated.
.ipt file attached.
Digby Scott CEng
TheCADWhisperer
Why do you want to do this?
DScott100
For simplicity.
TheCADWhisperer
Set to Shaded visual style rather than Shaded with Edges.
A single surface organic shape is not simple by any definition.
PaulMunford
An STL file is a mesh. Inventor deals with solids amd surfaces. Inventor 2017 has some tools to extract prismatic shapes from mesh surfaces. You can then trim and stitch these surfaces back together to get a solid.
Is that any help?
Paul Munford
Technical Onboarding Architect
Linkedin
Steven_Gao
Yes, it's nearly hard to merge the irregular faces into one face.
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
DScott100
Thanks for the advice.  No doubt organic shapes are complicated and also very challenging to model accurately.  I can work with the multiple faces, not a problem, just thought it may be easer and a little quicker with the work-flow to reduce the number of them.
