@15mmed12 wrote:
Can you do a sample?
There must be several ways to do it but here is one to make of those kind of things and I'm guessing that there isn't any "easy" way out.
I don't know your experience with Inventor so be lenient. 🙂
1. First you have to create enough of 3d sketches
2. After that you'll create coordinates in excel sheet for each point you're going to use afterwards
3. Then you'll import those points to the 3D sketch
4. Use Line and Acr Center Point tools to create solid line
5. Create 2d sketch for circle which going to be wire
6. Sweep the circle (Profile) via line (Path)
8. Create an assembly file and Place enough of those net parts
9. Create relations between these parts
Of course you could sweep whole net at once but there will be thousands on points and it would be quite difficult to think..
I hope this helped you bit further. In attached zip-file you'll find all these files
Tommi
