How to create wire mesh
Message 1 of 32
Hello Guys ,
I have to model wire mesh structure which i attached .
Replies (31)
Message 2 of 32
Hi
Is it made of by single wire ?
Tommi
Message 3 of 32
Yes
Message 4 of 32
Then I can't find any other way but find coordinates for every bending points, create 3d sketch line by using coordinate points and draw circle as wire in the end and then sweep the circle and use line as path.
There is much even features and you could use retangular pattern -tool to create more of those, then you don't have to sketch all of those features but only one.
Tommi
Message 5 of 32
Can you do a sample?
Message 6 of 32
Sure, it takes a while.
Tommi
Message 7 of 32
There must be several ways to do it but here is one to make of those kind of things and I'm guessing that there isn't any "easy" way out.
I don't know your experience with Inventor so be lenient. 🙂
1. First you have to create enough of 3d sketches
2. After that you'll create coordinates in excel sheet for each point you're going to use afterwards
3. Then you'll import those points to the 3D sketch
4. Use Line and Acr Center Point tools to create solid line
5. Create 2d sketch for circle which going to be wire
6. Sweep the circle (Profile) via line (Path)
8. Create an assembly file and Place enough of those net parts
9. Create relations between these parts
Of course you could sweep whole net at once but there will be thousands on points and it would be quite difficult to think..
I hope this helped you bit further. In attached zip-file you'll find all these files
Tommi
Message 8 of 32
Can you give me a ipt file of this thing??
Message 9 of 32
Yes, it in "an example pin.zip" file which I attached already
Tommi
Message 10 of 32
can you do as i am giving in a image???
Message 11 of 32
Do you mean just the file without zipping it ?
Here are those, .ipt and .iam files
Tommi
Message 12 of 32
No
i want this type of structure can you form it
please..
Message 13 of 32
You want me to create your wire mesh for you ?
Message 14 of 32
yes
Message 15 of 32
JDMather
I would use a cosmetic texture rather than model the geometry, but if you really want to model - see attached.
(adapt as needed)
Message 16 of 32
@Anonymous wrote:
yes
Sorry, can't do that. What I was trying to do, was to teach how you could do it by yourself and learn how to use this tool.
No one do my job for me, therefore I don't do other's work. At least not without proper salary.
Tommi
Message 17 of 32
can you give you whatsapp no?
Message 18 of 32
No, I don't use it.
Message 19 of 32
can you provide me a knot.ipt file as mentioned in tutorial given by you
Message 20 of 32
No, it wasn't me like you could see.
