Inventor Forum
how to create movie with slicing plane / cross section
10 REPLIES 10
Message 1 of 11
1127 Views, 10 Replies
Dear forum users,
I have a question about creating a movie in Inventor. It is for me possible to create a simple rotating movie, or change angles/positions of parts of the assembly. However, I do not want to do that.
I would like to make a movie in which my assembly 'get's sliced' by a plane and reveals the internals of the assembly. More or less I mean something like this: https://www.youtube.com/watch?v=NyLfJGDbKqk (not my video, not my assembly)
The purpose of this is an instructional movie to clarify to the viewer the cross sectional drawing from this assembly.
Any help on where to start would be much appreciated.
With kind regards,
Toby
10 REPLIES 10
Message 2 of 11
mdavis22569
What version of Inventor ..
in 2017, and in an IPN, Presentation file you should be able too
Mike Davis
Message 3 of 11
admaiora
you can do it in Showcase
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 4 of 11
Rob67ert
Hi Toby,
Welcome to this Forum.
I guess you like to do this: http://blogs.rand.com/manufacturing/2013/07/recording-a-section-view-going-through-an-assembly.html
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 5 of 11
in reply to: mdavis22569
Hello, mdavis22569,
Thanks for replying and Is should have mentioned the version... I am working with Inventor 2014
is it possible to use a presentation file to create a movie? Autodesk customer support told me that the only option is to use Inventor Studio, and they continued by saying I should check the internet how to use it.
Toby
Message 6 of 11
in reply to: admaiora
@ admaiora
Thanks for responding. I am not sure if I can use Showcase. I suspect it is not automatically part of Inventor?
@ robert.vdrijst
Thank you, that is exactly what I meant. I am going to dive in it asap. Hope it will work for version 2014.
regards,
Toby
Message 7 of 11
Rob67ert
This was made with 2014.
Robert
Message 8 of 11
admaiora
Hi Toby,
no, Showcase is not present in Inventor but often is present in the Product/Collection Suites.
If you haven't it, you can animate the cutting plane in this way.
Admaiora
Message 9 of 11
JDMather
Set internal color properties of part files. (must be done at the part level).
Extrude-Cut feature in assemblyt driven by Parameter.
Animate Parameter in Studio.
Done!
Message 10 of 11
Hello everybody,
Thank you so much for your quick response! It was really helpfull.
In the end I used the solution that admaiora as submitted.
@ admaiora, thank you.
It is my sentiment that creating a movie in inventor is still WAY to cumbersome and complicated. I am convinced that that Inventor should implement an easier way. However, in the end I got the movie I wanted.
Best Regards,
Toby
Message 11 of 11
Wow - nice! Thanks for this!
Very helpful, and not hard to do either.
Cheers
Technology Administrators
