Inventor Forum
How to create a pre-dimensioned drawing drop-in
4 REPLIES 4
292 Views, 4 Replies
I am trying to see if there is a way to create a thread detail callout that I can drop into a drawing that is already dimensioned correctly (refer to picture). Butress Thread Callout.JPG
I would like to be able to drop this in without actually having to go create it in the model then do a detail on the drawing and dimension. I realize I could make an actual part file so I could make it as needed and then drop it in wherever, but is there some kind of way to do this and have the dimensions already called out? I looked into the Sketch Symbols but, from what I can tell, it doesn't look like it can do that.
If anyone has any insight that they could offer I would appreciate it.
4 REPLIES 4
Cadmanto
What you could do is create a sketched symbol in your drawing format.
Then with the drawings you need it in, just insert the symbol.  This would not be associated with any model.  It would require a little work in sketching it upfront, but once done, easy peasy to insert.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
I had thought of that, I just didn't know if there was an easier way.
Cadmanto
The only other thing I can think of besides iLogic, would be to create a sketch block.  Just not sure if these work well with drawings as the symbols do.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Inventor Pro 2020
Best Regards,
Scott McFadden
I think the sketch symbols may be the easiest for this situation. Thank you!
