I am trying to see if there is a way to create a thread detail callout that I can drop into a drawing that is already dimensioned correctly (refer to picture).
I would like to be able to drop this in without actually having to go create it in the model then do a detail on the drawing and dimension. I realize I could make an actual part file so I could make it as needed and then drop it in wherever, but is there some kind of way to do this and have the dimensions already called out? I looked into the Sketch Symbols but, from what I can tell, it doesn't look like it can do that.
If anyone has any insight that they could offer I would appreciate it.
Solved by Cadmanto. Go to Solution.
What you could do is create a sketched symbol in your drawing format.
Then with the drawings you need it in, just insert the symbol. This would not be associated with any model. It would require a little work in sketching it upfront, but once done, easy peasy to insert.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
The only other thing I can think of besides iLogic, would be to create a sketch block. Just not sure if these work well with drawings as the symbols do.
Inventor Pro 2020
