Hi! Like Brian mentioned earlier, Inventor is not yet able to import Navisworks file directly. You would have to export it to FBX file and then use 3D Studio Max to export as STL and then import it to Inventor.
Do you mind elaborating the geometry or design you are working on in Inventor requiring Navisworks' file?
Many thanks!
Hey Johnson!
Not sure if the user is going to be able to provide examples, but I run into this often with factory layouts and / or 3D process piping. Clients will receive a Navisworks file and need to work off of this geometry. The FBX workflow is nice, but it would be even better if a user could import / convert the FBX directly into Inventor. Just my two cents... Hope this helps and have a most blessed night!
Peace,
Pete
Hi Pete,
This is an interesting idea. It is indeed captured in Inventor Ideas forum. But, at the moment, there are only 4 votes. Please add your vote.
https://forums.autodesk.com/t5/inventor-ideas/import-navisworks-data/idi-p/7424574
Many thanks!
There is a function to go from Inventor to Navisworks in the Factory Design Suite, but not the other way around.
So far the best workflow others have found is to import the Navisworks file into 3DS Max, and then export from 3DS Max as an STL file. Surely this has to be something Autodesk has to work on in the future.
I can see bring something in as FBX, and being able to reference in NWD/NWC files, but converting them directly to Inventor format isn't a good idea. For starters the way Navisworks converts objects to faceted surfaces (for speed purposes) results in loss of precision, and that loss of precision can vary such that one source may be more precise than another. You'll end up with much the same problem as trying to convert a mesh generated from importing a complex STL file.
If the originator is unwilling to provide the model in the original format, or in a neutral format like STEP or IGES, then it's time to check whether you actually have the rights to that content. Trying to reverse-engineer a Navisworks model isn't a suitable way to get around that restriction.
