how to convert each assemblies in autodesk inventor to Revit family file (RFA file format)
rsnkotak
Observer Observer
rsnkotak
Observer
Observer
I want to convert each assembly in an Inventor file into a separate Revit Family file (RFA). Could you please provide a solution for this? Thank you in advance for your prompt response.
CCarreiras
Hi!
Inventor Revit Interoperability tool will be installed along the process(if is not installed yet).
Go to BIM environment
Simplify the model if it is somehow complex (lots of holes, fillets chamfers, etc), if not simplified, the file it will turn in a big size file to use in Revit.
... and convert
Check the video:
Note:
You can convert also in a Revit file directly (RVT file, not RFA file):
CCarreiras
