Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
How to check Inventor version
4 REPLIES 4
JoãoASilva
1162 Views, 4 Replies
Hello!
I see many people refering their Inventor version (ex.: IV2021.2.2).
How can I check my version?
I've tried thru the Control Panel and my Autodesk account, but to no avail.
Anyone can point me in the right direction?
Thanks 😊
João Silva
Mechanical Engineer
If what I said solved your problem, or answered your question, please use the ACCEPT AS SOLUTION or KUDOS buttons.
Or if it helped you, please hit "LIKE"
Inventor Professional 2023.3, Build 359
4 REPLIES 4
-niels-
in reply to: JoãoASilva
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
JoãoASilva
in reply to: -niels-
I had been there, but since the release only said "2021" I thought it wasn't correct 😅
Thank you @-niels- !
João Silva
Mechanical Engineer
-niels-
Time to update then! 😉
Also, for anyone coming across this, this is also the window where you can press CTRL-D to get a diagnostics window on what underlying changes may be present in a file.
Disclaimer: This is an undocumented feature in Inventor, created for internal use by Autodesk.
Niels van der Veer
The Netherlands
JoãoASilva
I've done it already!
Also, thanks for the tip 😉
João Silva
Mechanical Engineer
