Hello!
I see many people refering their Inventor version (ex.: IV2021.2.2).
How can I check my version?
I've tried thru the Control Panel and my Autodesk account, but to no avail.
Anyone can point me in the right direction?
Thanks 😊
João Silva
Mechanical Engineer
If what I said solved your problem, or answered your question, please use the ACCEPT AS SOLUTION or KUDOS buttons.
Or if it helped you, please hit "LIKE"
Inventor Professional 2023.3, Build 359
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I had been there, but since the release only said "2021" I thought it wasn't correct 😅
Thank you @-niels- !
João Silva
Mechanical Engineer
Time to update then! 😉
Also, for anyone coming across this, this is also the window where you can press CTRL-D to get a diagnostics window on what underlying changes may be present in a file.
Disclaimer: This is an undocumented feature in Inventor, created for internal use by Autodesk.
Niels van der Veer
The Netherlands
I've done it already!
Also, thanks for the tip 😉
João Silva
Mechanical Engineer
