how to change model xyz orientation
WILLIAMF
Message 1 of 10
WILLIAMF
HI,
How do I change the XYZ measurement in a 3-D model so it matches the IDW view placement in a drawing?
I attached a model and drawing. The drawing dimensions are what I need X=8.628 Y =7.220Z=.514.
When I measure the model from flange to flange workpoints I get different dimensions.
Dell Precision 5820
Windows 10Pro
Quad Core Intel Xeon
32 Gb SDRam
NVIDIA Quadro
Product Design Suite 2019 Ultimate
Replies (9)
Message 2 of 10
WILLIAMF
Here is the idw I forgot to attach with the orientation and desired dimensions.
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 3 of 10
Hello WILLIAMF,
Here's what I would do. Place your component in an assembly all by itself, constrain it the way you want it with respect to the origin, then shrinkwrap it. If you want to leave open the opportunity to change the component and still have it display in the drawing in the desired manner, take care whilst constraining. But if it is an imported model from somebody else, like a vendor, you shouldn't have to worry too much.
Message 4 of 10
WILLIAMF
thanks
It is an imported IGES file from a vendor. They supply model and drawing file with only the XYZ dimensions they require from flange face to flange face.
My job is to create a working manufacturing drawing.
Seems I need to place different views in the IDW to get the 3 dimensions while I thought it may be something simple like change options default XYZ view orientation but that does not seem to work either.
its a dumb solid I get, but will try your suggestion. Even measuring from point to point in the model I get different measurements than what is desired on the IDW file I sent.
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 5 of 10
MechMachineMan
@Anonymous wrote:
Hello WILLIAMF,
That'll create issues with having unnecessary duplication of files of the same part number, as well as causing issues with having the component replace to a new location if the part in question is used in multiple locations.
For an ipt:
- Use the Move Body command within the part environment and rotate the part. NOTE: you can also translate the part with this command to move the origin any way you like
For an iam:
- Unground your base component, and re-constrain the origin planes as required to orient the part as desired.
Note: Changing origin locations CAN throw off an IPN file's display of components as it is partially based on the origin planes/orientation of the component parts.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 10
WILLIAMF
Move bodies does not appear to work on this part. Did you try it on the model I sent?
thanks for the info
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 7 of 10
@MechMachineMan wrote:
@Anonymous wrote:
Hello WILLIAMF,
For an ipt:
MechMachineMan,
Not if you break the link it wont. The base is unnecessary once the shrinkwrap is created anyway. Delete the unsatisfactory original and rename the independent shrinkwrap with the name of the original file and off you go. This method has worked consistently for me with stp file conversions from McMaster.
I would think the Direct Edit feature would be able to accomplish the same thing as you're suggesting,MechMachineMan
Message 8 of 10
WILLIAMF
got it! Thanks a lot!
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
Message 9 of 10
SBix26
Here's your file (2017 format) after using the Move Body tool to re-orient.  I simply used the Measure and Measure Angle tool (set to All Decimals precision) and copied the measurements to the Move Body offset fields.
Just another way to get there.
Sam B
Inventor Professional 2018.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Message 10 of 10
WILLIAMF
thank you
I never had a need to use that command. Interesting though.
I will study up on the usage of it.
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
