Help: stretching or add a piece between bend and flange
I have  tried to stretch the flange with the big whole and the small holes around it but i cannot do it.
i want to add an extra 20mm material between the bend and the holes. This extra material has to be straight instead of  the angluar
shape now. So just the 20mm had to be straight with the same width.
How can i do this?
salariua
Like this:
I don't have access to 2018 for a couple of hours but just trying to see if this is what you're after. Check 2017 attached
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
thnx! This is what i mean, how did you achieved this?
salariua
Open the attachment in my original post. It is a 2017 file format but you'll get an idea of what I did.
Split bodies, move one up 20mm extend face to reconnect.
Since I don't have access to 2018 now I can only use solid body editing commands.
Adrian S.
blog.ads-sol.com
