Hello everyone,
Does anyone knows how to add shortcuts to this dialog?
Thanks!
Solved by Curtis_Waguespack. Go to Solution.
Solved by bradeneuropeArthur. Go to Solution.
Use Frequently Used Subfolders in the project *.ipj file.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hi @DSantos23
Just to expand on the previous post in case it wasn't clear, if you edit your Project file (*.ipj) you can add shortcuts using the "Frequently Used Subfolders" node, here is more detailed information and an image of where to locate the Frequently Used Subfolders.
I hope this helps.
Curtis
Refine your Project | Inventor | Autodesk Knowledge Network
Unfortunately we won't be able to use this solution as our Project file is locked from changes in Vault and only enterprise admins can edit it. It makes sense, because particular shortcuts are a user preference and do not apply to everybody.
But I understand that your answer is a solution for my question.
Thank you very much!
You can remove the readonly flag from the ipj project file.
Now you can edit it as you want!
Arthur Knoors
Project file is readonly!
Arthur Knoors
Well... The file itself it is not... I cleared the flag on the ipj file...
Is that something defined in the ipj creation then?
Thanks a million Brad...
I figured I could use the Project Editor in the Autodesk Inventor folder in the Start Menu and add those entries... Thanks everyone for the help!
