Forum
I would like to remove grill and thicken feature from my back cover of tapcard hosing.
I suppress them, I get a solid. I think its because of boundary patch.
Can someone anyone help me remove the extrude fill (solid) feature, I want it to be an extrude cut.
Haziq
Solved by kelly.young. Go to Solution.
Solved by Xun.Zhang. Go to Solution.
Hi! There are several Combine features in the part. Which one are you talking about? Could you edit the Combine feature and change the operation type?
Many thanks!
@Anonymous,
I am not sure which extrude fill feature you are talking about, but Direct Edit, delete command might help you out.
Hope it helps!
@Anonymous my first thought would be:
This will get you back to before the grill without any sick features.
Remember that every feature you create has to have a reason and will have other parts that might be dependent.
The farther down the rabbit hole you get the harder it will be to change something at the beginning, especially in a single multi-solid part.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
johnsonshiue
Sorry for not labeling my workflow.
I personally do not know which one as I didn't give a name to all of my features in modal tree.
I will implement it in my next design.
Thanks for taking the time to view my part.
Yours Sincerely,
Haziq
