How do I measure the loop length of a 3D Sketch and set it as a parameter?
JohnRambo4
Message 1 of 9
JohnRambo4
How do I measure the loop length of a 3D Sketch with splines and set it as a parameter? For example I want the total length of a hose to be saved as a parameter to show up the Description or QTY field on a drawing. Obviously you can measure it with the Measure tool, but how to set the length to a Parameter? Thanks.
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
This is a question for @bradeneuropeArthur
Kacper Suchomski
Message 3 of 9
andrewiv
You will have to have an iLogic rule to accomplish this.  Here is a rule that used to use for this exact purpose.  I would set this rule to run on the geometry change trigger.
Dim oDoc as PartDocument
Dim se As SketchEntity3D
Dim oParameters As Inventor.Parameters
Try
	oDoc = ThisDoc.Document
	se = oDoc.ComponentDefinition.Sketches3D("3D Sketch1").SketchLines3D(1)
	oParameters = oDoc.ComponentDefinition.Parameters
	oParameters.Item("HOSE_LENGTH").Value = ThisApplication.MeasureTools.GetLoopLength(se)
Catch Ex2 As Exception
	MessageBox.Show ("ERROR, HOSE LENGTH VALUE WILL NOT UPDATE" & vbCr & vbCr & vbCr & Ex2.Message, _
		"SKETCH LOOP LENGTH ERROR", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Andrew In’t Veld
Designer / CAD Administrator
Message 4 of 9
johnsonshiue
Hi! Another approach is to use an iLogic rule to get the volume of the tube and divide it by the tube cross section area. The result should be the length.
Many thanks!
Software Test Engineer
Message 5 of 9
JohnRambo4
This worked. I just needed to create a HOSE_LENGTH parameter before running the code, and checking the Export box in Parameters. Now I can have the length populate in the part description. Thanks. How do I get it to auto update on geometry change?
Strange there isn't a way to dimension the whole length in a sketch but whatever.
Message 6 of 9
bradeneuropeArthur
Would something like @kacper.suchomski may mention help you?
https://youtu.be/zN06eaBr2eY
And please vote the idea if you think this is a good addition for future releases of Inventor.
https://forums.autodesk.com/t5/inventor-ideas/sweep-length-to-parameter/idi-p/13005488
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 9
JohnRambo4
That tool looks great. Did you make it available somewhere?
Message 8 of 9
bradeneuropeArthur
Could you send me a private message maybe we can have a look at the possibilities.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
andrewiv
To have it update whenever the geometry changes you just have to add the ilogic rule to the the event triggers.  Just put it under the part geometry change trigger and then it will update the parameter any time the part is changed.
Andrew In’t Veld
