- Mute
- Permalink
- Report
Ill try to explain this issue quick.
I have an adaptable assembly. I have created a workplane where I want it with a sketch and a fully constrained construction point. A hole is made from this point location and I have set it to go "Through All" components of this assembly. When I first build the hole, it works great.
Since the assembly is adaptable, when it grows more pieces are added in which the hole must also go through however when the assembly grows, the hole does not adapt properly. I have found the "add participant" option but to me this is just another annoying manual workaround for these types of problems.
I am in the process of trying to make my assembly 100% adaptable through use of iLogic and this is just another hiccup. If anybody knows if there is a way to get the result im looking for I would really appreciate the help!
Im using Inventor 2016 btw..
Sandro
